what would too much oil look like?
Old Apr 4, 2008 | 08:23 AM
jay_rich's Avatar
OKay I have a 383 LT1 With a moroso Pan. The previous owner (my friend said he ran 8 quarts but he has a oil filter relocation kit and and big as HP filter). He ran moble 1 15-40
I am running 8 quarts of 15-40 Royal Purple with a stock filter.
Now i pulled my dipstick and there was a little gray at the top of the dipstick. I checked my oil seperator that was on the intake and it was full of gunk. I did just change the filter bc the old one wasnt giving my motor over 35psi.
Could these simptoms be from too much oil OR bc the filter pluged?
I am running 35ishPSI HOT idle, 60psi Crusing.
The motor runs strong and hard also.
Also I think im leaking a bit from the dipstick at the block (bc i didnt RTV it and have been moving it alot)
Any input aprreciated!
Jay
Old Apr 4, 2008 | 10:59 AM
ulakovic22's Avatar
Need more info about the pan and what it can hold. With a stock pan and filter that would be way too much and probably why your catch can is full of crap.
Old Apr 4, 2008 | 11:48 AM
jay_rich's Avatar
Sorry pan is a Moroso 20205 pan. Filter is a stock size filter. Oil is 15W-40 Royal purple (8 quarts)
Jay
Old Apr 4, 2008 | 02:41 PM
cnorton's Avatar
If the pan was installed with the correct oil pump pickup, you're way over-filled on oil. Just because they say the capacity is seven quarts doesn't necessarily mean you should put that much or more in it.
To provide a comparison, I run a Moroso 21239 pan with the matching pickup on my LT1 drag car. While the capacity of my pan is much greater, I normally run 5 quarts of oil with a standard capacity pump. If needed, when the car needs to be a little faster, I run 4 quarts on a quarter-mile pass at 8200 rpm with no worry. The only time the pressure fluctuates is during the shutdown but I normally click the motor past the lights anyway.
You should try to make sure the pick-up was matched to the pan. It should be positioned about a 1/4 inch off the bottom of the pan. You don't need a high volume pump so make sure you know what you have.
Old Apr 6, 2008 | 08:28 AM
sn8ke eatr's Avatar
5 - 5.5 quarts is generally enough
Old Apr 6, 2008 | 12:50 PM
jay_rich's Avatar
Thanks guys I ended up switching to Valvoline V1 20W50 Race oil. I am running 6.3 quarts total and I am not seeping oil or pushing any now .
The oil that came out looks great too.
Also I figured out why the wideband was going nuts....when i got my Y pipe made the guy had the wire over the tail stock and it fell onto the DS and wore down the wires..
Car seems to be running hard .
MT drag radials and spinning the tires cruising at 70 KPH :O hehehehe
Jay
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
