What would cause these ignition problems?
Old Jun 3, 2003 | 11:42 PM
Euclid's Avatar
When I get on the gas from a stop, it will act like it's going to die, then it goes.
When I'm driving it sounds like a machine gun, or like you're driving over a washboard. It varies with RPM, the higher the RPM's, the faster the machine gun shoots.
Just did opti and wires. Could it be a wire not all the way on the plug? Could it be a plug not all the way in the hole?
Thanks!
Old Jun 3, 2003 | 11:45 PM
94GrayV6's Avatar
Check the coil.
Old Jun 4, 2003 | 11:18 AM
Euclid's Avatar
No... Coil wouldn't cause repetitive misfire on just one cylinder. This is extremely rhythmic.
Old Jun 4, 2003 | 12:11 PM
Then check all your wires.
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
