what wire for ACC on switch??
Old Apr 12, 2004 | 04:41 PM
Brundle's Avatar
I'm wiring two illuminated switches in the ashtray area near the shifter. i'm replacing the CAGS switch and adding a switch for ASR reverse. anyways, since both the switches will be illuminated, i'm wondering what wire i can tap into to make these switches only illuminate when key is in the ON position?
TIA,
Ryan
Old Apr 13, 2004 | 09:34 AM
Brundle's Avatar
TTT
anyone? please?
Old Apr 13, 2004 | 10:58 AM
There should be a switched +12V power source in the fuse block at the end of the dash.... a small square hole with a 0.25" male spade lug in it, labled "IGN"...... on the Pontiacs is right here where the orange wire is connected. In the Camaros, I think the block is upside down compared to the Pontiacs.
Old Apr 13, 2004 | 05:56 PM
Brundle's Avatar
hmmmmmm.......any other wires in the harness by the shifter that i can just tap into instead? was tryin to avoid running several wires over to the fuse panel if possible
Heathen1
Jan 2, 2016 04:27 PM
Jlo
Feb 3, 2015 09:41 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Jul 4, 2005 05:00 PM
Ryabut98
Sep 3, 2002 11:45 PM
