What is this wire?
Old Apr 30, 2008 | 10:11 PM
BCdawg57's Avatar
What is this wire?
found that this wire is sniped on my harness. what is it to?
Old Apr 30, 2008 | 10:38 PM
JooneJune's Avatar
def need to find out what connector that is. (COLOR) they are coded A-? ports what wire is the port in?
Old Apr 30, 2008 | 10:55 PM
BCdawg57's Avatar
I do believe it is the BLUE port. It could very well be the RED one also. I cant make sure right now it is at a different house.
It looks like it was purposly cut like that, there is a section of wire missing, its not just snipped. AFAIK this was taken out of a perfectly fine running vehicle.
Old Apr 30, 2008 | 10:57 PM
camzaro28's Avatar
http://shbox.com/1/1995_pcm_conn_c.jpg
Old Apr 30, 2008 | 11:02 PM
BCdawg57's Avatar
am i correct in reading that is the ground wire?
Old Apr 30, 2008 | 11:08 PM
camzaro28's Avatar
what color is the wire? Looks purple to me.
Old Apr 30, 2008 | 11:09 PM
BCdawg57's Avatar
black and white
Old Apr 30, 2008 | 11:14 PM
JooneJune's Avatar
black and whites are normally grounds, make sure its the right color connector your looking at and the right port...
Old May 1, 2008 | 09:03 AM
What kind of car? Your signature indicates you have a "1991 Z/28 LB9 5spd". If you had an LT1 with a 6-speed, I'd guess someone might have cut the wire to the "skip shift" indicator light. But without knowing the details of the car, its sort of hard to help.
Old May 1, 2008 | 01:51 PM
BCdawg57's Avatar
THe harness you are looking at is out of a 94 LT1/M6 car.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
