What will I run
Old Mar 1, 2003 | 01:49 PM
unTAmedLS1's Avatar
What will I run
I have a 97 Formula 6speed w/ 3.42 gears. It has mildly ported heads a comp xe 224/230 112LSA cam, Jet-Hot LT headers, K&N CAI, 85MM MAF, Port matched intake and full exhaust with a cutout. What does everybody think I'll be in the range of with decent traction. Car went 13.9 @ 104.4 basically stock with a crappy 2.3 60'
Old Mar 1, 2003 | 02:07 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: What will I run
just get some drag radials, tuning and run a mid 12 like i told ya
Old Mar 1, 2003 | 02:12 PM
COMNBYU's Avatar
with traction, i would say at least mid 12s. low 12s are definatly within reach.
good luck!
jon
Old Mar 1, 2003 | 02:24 PM
unTAmedLS1's Avatar
Haha I was just hoping someon had the same setup Trey some guy on LS1tech said he was ruinning an 11.9 on it but I didnt think It could be that much considering his car is 3600lbs which is at least 200 over mine
Old Mar 1, 2003 | 02:27 PM
treyZ28's Avatar
take the sand bags out of the trunk
a 3800 lb f-bod is one fat bitch
Old Mar 1, 2003 | 02:40 PM
95TA8280's Avatar
I'm surprised Trey didn't tell you how he thinks you can hit under 12s....
You have a ton of speed work, and no suspension from what I can tell. You need traction and cut down that 60'? Get some suspension stuff and that'll cut down a ton!
Old Mar 1, 2003 | 02:55 PM
unTAmedLS1's Avatar
Oh yeah I also have rear LCAs and was planning on getting SFCs and torque arm. Also Ill be running on some bfg drag radials. Hoping to cut at least a 1.8..
Old Mar 1, 2003 | 04:42 PM
unTAmedLS1's Avatar
ttt anyone have a similar setup so far sounds bout right though
Old Mar 1, 2003 | 05:39 PM
treyZ28's Avatar
11's will be rough, especailly with a 6spd
hooking on a 6spd is hard
12.2-12.6 is my guess
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
