what will this cam do in my car? info inside
Old Feb 17, 2005 | 11:57 PM
94PurplePearlZ28's Avatar
it is a schnieder racing camshaft.
...1..............2..........3.......4......5..... ..6........7.......8.......9...
(22072) (284-94RH) (284) (294) (222) (232) (.480) (.500) (114)
1.Part Number
2.Grind Number
3.Int. Duration (Gross)
4.Exh. Duration (Gross)
5.Int. Duration (.050")
6.Exh. Duration (.050")
7.Int. Valve Lift 1.5rr
8.Exh. Valve Lift 1.5rr
9.Lobe Separation
i bought it from a friend that had it in his 383 for 2k miles. he built it for nitrous. and said it was a nitrous cam.
its been along time since i heard it, so what do you think it would sound and run like with stock heads, manifolds (temporary), 1.6rr good springs and stock tune for now.
will it lope any? will it improve power any? and with that lobe seperation and duration will it hurt mileage much?
Old Feb 18, 2005 | 12:26 AM
sssalah's Avatar
Re: what will this cam do in my car? info inside
Those spec are very similar to the cc305, so it should run similar. It will have a slight lope, max power around 5500, and it’ll be a good n2o cam due to the large lsa and good split of 10 degrees.
Old Feb 18, 2005 | 12:40 AM
i want it to have a decent lope when you listen for it, but if i was to just pull up to someone and say its stock except exhaust. they would believe me.
maybe i could idle it down to 600 or so for sound, then hold the idle up to 900 when i talk to someone at a light.
what type of increases are people seeing with the cc305?
Queens94z28
Dec 20, 2014 09:11 PM
bernie1951
Dec 10, 2014 10:03 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
