Cam choice??
Old Feb 17, 2005 | 11:56 PM
Youlost's Avatar
Cam choice??
Well I have a 95 Z28 and have the following mods: Hooker lts, y-pipe, cat-back, k&n cold air intake.
What cam should I go with? I dont want to port the heads or anything so it will have to be fine with stock engine with those mods. So which cam do you suggest? Website url I can purchase one from? Is buying a used cam bad? What kind of power should I expect with those mods and the cam?
Thanks a lot
Jamie
Old Feb 18, 2005 | 12:11 AM
sssalah's Avatar
Re: Cam choice??
How high would you want to rev it up? is it a manual or auto? what's the stall if auto? can you bare a lopey idle.
There are alot of choices, depending on your preferences.
Old Feb 18, 2005 | 12:17 AM
Youlost's Avatar
Re: Cam choice??
I have a m6, don't really want to go over 5800. as long as it run good im not worried about the idle.
Old Feb 18, 2005 | 12:56 AM
sssalah's Avatar
Re: Cam choice??
Here are some choices:
GM 846, 222/230 @ 0.05", 0.509/0.528, 112 LSA
CC 305, 220/230 @ 0.05", 0.510/0.510, 114 LSA
CC 503, 224/230 @ 0.05", 0.503/0.510, 112 LSA
If you're not planning on using n2o then go with 112 LSA, it'll be a little lopey but should give more power.
rideordie
Nov 5, 2019 04:52 PM
Apr 3, 2015 10:54 AM
transam_388
Mar 15, 2015 11:53 AM
95chwagon
Jan 13, 2015 09:19 PM
