What weight oil should I run at 79k+?
Old Jun 15, 2004 | 07:50 PM
JoeliusZ28's Avatar
Right now im using 5w-30 [Mobil 1] like it says to use on the oil cap, but im wondering if I should switch to 10w-30 with my mileage... thoughts?
thanks
Old Jun 15, 2004 | 08:31 PM
RE AND CHERYL's Avatar
I would run 10w-40 in the summer and 10w-30 in the winter.
Old Jun 15, 2004 | 08:36 PM
25thBird's Avatar
I run 5W-40 at 86,000 miles, and my friend recommended i switch to 10W-30 since my oil pressure is a little lower than before.
Old Jun 15, 2004 | 08:50 PM
Spinner's Avatar
Find a new friend. 40 weight is thicker then 30 weight
Old Jun 15, 2004 | 08:52 PM
25thBird's Avatar
So I should go with 10W-40 instead of 10W-30?
Old Jun 15, 2004 | 09:02 PM
JoeliusZ28's Avatar
forgot to mention... I dont drive the car in the winter. ...well I will on rare occasion actually, but it definetly is not my daily driver
also, my idle oil pressure is about 20, and my 'anything above 1500' pressure is 38'ish
Old Jun 16, 2004 | 09:58 AM
JoeliusZ28's Avatar
looking for more opinions
Old Jun 16, 2004 | 10:32 AM
ssbowtie1's Avatar
Why don't you try different weights for yourself and find out what works best for your application. Everyone has diffferent resuts, but IMO, as long as you run synthetic oil with a good filter, there's not much to worry about. You can try: 0w30, 0w40, 5w30, 10w30, 10w40, 15w50, etc. I think the only oil that you may see a difference with is 15w50 because its alot thicker. But once again, you may notice your car running undesireable with that weight oil. Just try something new every oil change until you find something you like. Good luck.
Old Jun 16, 2004 | 11:12 AM
tagz's Avatar
I've got 121,500 miles and i'm runnin mobile 1 senthetic, 5w30 with no problems. The only leak i have is my dip stick. Which Is becuae after i installed my headers I never installed the dipstick properly and lost the bracket. I have to get a new one.
Old Jun 16, 2004 | 11:32 AM
LWillmann's Avatar
My car has 96,600 or so on it and I'm running Mobil 1 5w-30.. With my mileage, I'm pleasantly surprised that I don't have to add any oil between changes.. I'm losing a tiny bit from the front cover somewhere, but it's really an insignificant amount.
Old Jun 16, 2004 | 12:21 PM
Joe Bellman's Avatar
throw in some 80-90 wieght, that should get the pressure up.
It worked on my Simplicity lawn mower. That thing used to have low oil pressure and burn oil pretty bad. A little 80-90 in there thickened things up......it been running that way for 2 years.
Old Jun 16, 2004 | 08:13 PM
96capricemgr's Avatar
M1 5w30 runs thin and with use can become a 5w20, a bit too thin for the LT1 reguardless of all the Vette crap and stuff, other 5w30 DO run thicker, before you say I am wrong do some research into actual analysis results. Best thing you can do is try some other oils and you will quickly find one that runs better, I would start with one of the 0w30-40, a 5w40, or a 10w30-40. Personally I am running a heavy duty engine oil usually marketed toward diesels but is gas rated, it is Rotella T synthetic 5w40 cost $12.88 a gallon at Walmart. I have a ZZ3 cam roller rockers and appropriate springs, and the motor is so quiet the guys I Power Toured with said it sounded stock, and the roller rockers are 30K mile old Proforms. I was supposed to do an analysis of my last fill of this oil, but had a friend over working on his car when I drained it I spaced out and forgot to sample till after it was all in the drain pan mixed with other oils .
Old Jun 16, 2004 | 09:13 PM
hsyr's Avatar
83xxx Miles on the clock and I switched from 10w-30 dino to
0w-30 German Castrol Synthetic and my oil pressure increased. Do a search on it, its closer to a 40w than a 30w and provides awesome bearing protection on LT1s.
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
bossco
Nov 29, 2014 10:18 AM
