What Valves?
Old Sep 17, 2004 | 07:37 PM
1BadBird's Avatar
What Valves?
I broke a Valve spring on my car and bent a valve (oh yay) so now my winter project is the top end of the motor. I think I'm gonna have Lloyd Elliot port my heads. I was wondering if anyone could offer an idea on what valves to go with? Lloyd said to stick with stock valves so most likely I will but GM wants an arm and a leg for them something like $15-$18 for exhaust each and $24-$26 for intake each. I've found them cheaper elsewhere I think Combination Motorsports sells Manley's for about $13 each, Lingenfelter sells sets of 8 int. & exh. for $99.95. Problem is I don't believe these are stock sizes. I'm not 100% positive what the stock sizes are . Any help would be appreciated
Old Sep 23, 2004 | 11:35 PM
DuronClocker's Avatar
Re: What Valves?
stock LT1 valve sizes are 1.94 int and 1.5exh, LT4 is 2.00 int and 1.55exh
Old Sep 24, 2004 | 12:47 AM
rpm4lalo's Avatar
Re: What Valves?
I used Manely Race-Flo valves, but they were not stock size, I went with 2.00I 1.56E
Old Sep 24, 2004 | 05:26 AM
1racerdude's Avatar
Re: What Valves?
If you can't get 2.0-1.56 get 2.02-1.60 and get them cut down.LE can do that,and the valves are much cheaper.
Get standard stems not the undercut stems,unless you want to break another valve.
Old Sep 24, 2004 | 08:59 PM
1BadBird's Avatar
Re: What Valves?
Thanks for the info and advice. I talked with Lloyd and he's gonna do 2.00 and 1.60 valves for me along with the rest of the top end goodies.
Old Sep 24, 2004 | 09:05 PM
Z-RATED94's Avatar
Re: What Valves?
Sounds like a good plan.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
