What Valves?
I broke a Valve spring on my car and bent a valve (oh yay) so now my winter project is the top end of the motor. I think I'm gonna have Lloyd Elliot port my heads. I was wondering if anyone could offer an idea on what valves to go with? Lloyd said to stick with stock valves so most likely I will but GM wants an arm and a leg for them something like $15-$18 for exhaust each and $24-$26 for intake each. I've found them cheaper elsewhere I think Combination Motorsports sells Manley's for about $13 each, Lingenfelter sells sets of 8 int. & exh. for $99.95. Problem is I don't believe these are stock sizes. I'm not 100% positive what the stock sizes are . Any help would be appreciated
Re: What Valves?
stock LT1 valve sizes are 1.94 int and 1.5exh, LT4 is 2.00 int and 1.55exh
Re: What Valves?
I used Manely Race-Flo valves, but they were not stock size, I went with 2.00I 1.56E
Re: What Valves?
If you can't get 2.0-1.56 get 2.02-1.60 and get them cut down.LE can do that,and the valves are much cheaper.
Get standard stems not the undercut stems,unless you want to break another valve. |
Re: What Valves?
Thanks for the info and advice. I talked with Lloyd and he's gonna do 2.00 and 1.60 valves for me along with the rest of the top end goodies.
Re: What Valves?
Sounds like a good plan. ;)
