What valve springs for CC305??
Hey guys I just need to know what the best valve spring there is for the cc305 and i also have 1.6 rr's. I want to be able to use as many of the stock parts as possible with the springs bc the rest of my valve train is practically brand new with the rebuild.
Re: What valve springs for CC305??
I ran the Crane 10308 spring kit with my CC305. I ran the K-motion K800s with my GM 847. Either will work. The 10308 springs are good to .600" lift while the K800s are good to .700.
Originally Posted by meangrn94ta
i just put the cc305 cam in my car last winter with 1.6rr's and i used the comp 986-16's that is what comp recomended. does that sound right?
Originally Posted by turbo_Z
FWIW that is what I would use. They should definitely work fine with that cam.
well i am currently running the 986's with stock heads and i did not have to grind on them. anything bigger and i think you would have to because the are a close fit. i did have to do some shiming though.
