What to use on bolts?
Old Jul 12, 2003 | 09:28 PM
Mr.Whitey's Avatar
I am in the middle of doing the LT4 Hotcam kit, vented opti swap, heads ported by Lloyd, CSI pump and Cloyes double roller. I know it's a general rule to use only antiseize on bolts going into aluminum but is that true w/ ALL bolts going into aluminum? In other words, what if anything should I use Loctite on during assembly?
I know this may be a stupid question to some but I just want to make sure I am doing it right the FIRST time.
TIA
Old Jul 12, 2003 | 09:56 PM
thewinner's Avatar
just use loctite on the cam bolts. thread sealant on the head bolts, intake manifold bolts. antiseize on any exhaust bolts.
btw, do you need head bolts? i have a set of ARP here.
Old Jul 12, 2003 | 10:08 PM
Thread sealant on water pump bolts, too.
Old Jul 12, 2003 | 10:18 PM
Mr.Whitey's Avatar
I'm glad I asked! Any specific thread sealant best to use?
I am just planning on reusing my factory bolts, unless there is a reason not to?
Old Jul 12, 2003 | 10:25 PM
thewinner's Avatar
doh, forgot about the waterpump bolts. might want some loctite on the cam retainer plate as well.
also on the rocker arm studs
just pick up some arp thread sealant
personally i wouldn't reuse old stock stuff in something so important.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
