What type of oil do I use for my A/C????
Old Aug 5, 2003 | 11:48 PM
cmbob67's Avatar
I was board at work so I decited to check my A/C. I hooked it up to the recovery machine, recovered about 1 lb of R-134, then vacumed the system and then charged it with 2 lbs. Although I didn't ask the machine to pull out the oil, I've been told that when you recover your system you pull out some of the oil from the compressor as well. I don't wanna burn up my A/C Compressor and I can't use the oil at my work because it's a dodge dealer and the oil that they have is for Mopar junk. I was warned that you should only use A/C oil that is recommended by GM. Where can I get this oil? If I haven't had any trouble with my A/C, should I even worry about it? What da ya tink???
Old Aug 5, 2003 | 11:52 PM
predator's Avatar
get a can of that oil that is compressed and put about 2 oz in there
notstock4long's Avatar
Re: What type of oil do I use for my A/C????
I would also like to know, so here is a TTT.
Will the autozone stuff work just as good?
Old Aug 6, 2003 | 12:18 AM
StrungZ's Avatar
i think its ether oil used in the accumulator... not sure, was for my old volvo
Old Aug 6, 2003 | 07:29 AM
cmbob67's Avatar
anybody else????
Old Aug 6, 2003 | 08:50 AM
You must use PAG (polyalkylene glycol) synthetic refrigerant oil with the R-134a system. The only way to know how much oil is in the system is to remove it all. Then you can put in the correct amount.
Old Aug 6, 2003 | 09:58 AM
cmbob67's Avatar
Now is there a particular PAG oil that I need to use or is any synthetic PAG oil OK? I was told that I probably didn't pull out too much oil when I recovered the R-134. I was also told that R-134 has oil in it as well so if I haven't heard any knocking comming from the compressor, I should be OK???
Old Aug 6, 2003 | 10:21 AM
Can't answer if you will be ok or not. As far as the PAG goes, as long as that is what you use (as I understand it, they are all synthetic), that should be good.
HectorM52
Jul 30, 2017 11:46 AM
timmy39120
May 8, 2015 11:41 AM
alex5366
Apr 1, 2015 09:27 AM
jasonduaine
Mar 7, 2015 09:44 AM
alphaauto
Feb 5, 2015 05:25 PM
