What is the tube for on the SLP intake?
Old May 7, 2006 | 12:22 PM
Bamfer9duce's Avatar
I have a 1995 LT1 with a SLP intake and I just noticed the other day that it has a tube with nothing plugged into it. I know this is an easy question but I couldn't find the answer. I have no air and egr so I figured something from that system plugs in there. I just want to know what is supposed to go in there and what are some common things I could plug it with. Also does having nothing in the hole greatly affect performance? Thanks
Old May 7, 2006 | 12:24 PM
Re: What is the tube for on the SLP intake?
Does it look like a 5/8" connection for a hose? If so, that's where the AIR pump air supply connects. You would need a 5/8" vacuum cap to close it off. Leaving the hole uncovered allows unfilterd, hot air from the engine compartment to enter your intake.
Old May 7, 2006 | 01:26 PM
Yeah it could only be for a hose because the tube has no threads. Do you know where I could get a 5/8" vacuum cap? Maybe a hardware store of some sort.
Old May 7, 2006 | 02:18 PM
Most well stocked auto parts stores should sell it, or be able to get it for you.
HarleyZ28
Oct 5, 2015 06:23 AM
Richardan15
May 30, 2015 08:36 AM
Jul 4, 2005 05:00 PM
