What Tools for Header install...
Old Feb 24, 2005 | 09:35 PM
  #16
SickWS6's Avatar
Re: What Tools for Header install...
you are going to need to cut the air pipe becasue it will just be in the way, you should see it so i just sawzalld it in the beggining
Old Feb 24, 2005 | 10:28 PM
  #17
glennxx1's Avatar
...you can keep the "plates" that bolt on the back of the intake and run to the exh mani' and cut out a cocola can to block it off...if u cant buy plates
Old Feb 24, 2005 | 11:04 PM
  #18
Don't Look Back's Avatar
Originally Posted by 97BBlackZ
What did yall do about the AIR and ERG system? I don't have any block of plates that i can use right now so what can i use instead of that? Also i have the cut the pipes for it?
After you remove the rest of the AIR system, there's still the metal pipe in a U-shape that goes under the crank hub in front of the oil pan. Its welded to a bracket that bolts to the block. Its easier just to cut the pipe to get it off.
Old Feb 28, 2005 | 05:35 PM
  #19
keng's Avatar
If I cut it will it through a code, also do I need extenders for the o2 sensors?
Old Feb 28, 2005 | 07:15 PM
  #20
Spinner's Avatar
Yes you need extensions. one at least 12" and one at least 18".
The pipe is just leftover from the AIR system. the only way to remove it is to cut in in one or more places.
Old Mar 1, 2005 | 12:02 PM
  #21
RyanB58's Avatar
My dads garage has prolly 100k in tools and I think I used every one, but the best tool was my own foot, or maybe my skinny *** arms, or ............
You get the point, what works for one person may not work for another.
Old Apr 1, 2005 | 04:45 PM
  #22
blind527's Avatar
Oh man, I don't have those kinds of tools I might have to have a shop do it.
Old Apr 1, 2005 | 08:53 PM
  #23
blind527's Avatar
Why do you need to disconnect the battery?
Rod Bender
Nov 7, 2023 02:30 PM
rick350
Mar 16, 2015 02:59 PM
ChrisFrez
Feb 22, 2015 08:47 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
