what are the symptoms of a normal sbc t-stat in an lt1
Old Aug 18, 2011 | 05:14 AM
L.dookie's Avatar
There it is. It's been years since i put the thermostat in. I didn't buy it, so i really don't know. I'm just now learning that there is definitely a difference between an sbc and an lt1 thermostat. i'm just curious as to what symptoms one might have if a normal sbc thermostat is installed. my car runs fairly hot, i have overheated it a few times driving it around town. but driving at speed (40 and up) it runs around 150. when i overheated it my cooling fans were on a switch. even with the fans running on high it still overheated. i've recently put the fans back to factory. just being curious and i'm not going to jump at the chance to get coolant on my opti just to make sure i have the right t-stat. Since i normally drive country roads this isn't a huge issue. Thanks in advance.
Old Aug 18, 2011 | 07:13 AM
RamAir95TA's Avatar
Re: what are the symptoms of a normal sbc t-stat in an lt1
The SBC thermostat won't seal the top passage of the pump, so it would be more similar to running with no thermostat.
It should be easy enough to check though. Drain some coolant out of the water pump/radiator, pull off the water neck and pull out the thermostat.
Courtesy of shoebox:
http://shbox.com/1/tstat.jpg
Alex Barnes
Jan 24, 2015 10:21 PM
97z28k&N
Jan 9, 2015 04:58 AM
jayblev95
Dec 1, 2014 06:55 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
squinn
Aug 4, 2002 01:06 PM
