383 overheating
Old Aug 16, 2011 | 10:16 AM
importkiller94's Avatar
383 overheating
Last night I finally fired up my new 383. When I added coolant prior to the startup I noticed the weep hole on the bottom of the water pump was leaking. I started it anyway and it runs awesome but of course it overheated real quick. Way are the pros and cons of using an electric pump over a cam driven, what should I go with? And any other tips on how to keep this bad boy cool would be greatly appreciated, thanks a lot guys
Old Aug 16, 2011 | 10:25 AM
RamAir95TA's Avatar
Re: 383 overheating
Pros - Dyno-proven 8-10whp gain, more control over the cooling system (can circulate coolant with the engine off), allows for use of a double roller timing chain.
Cons - They eventually will fail with no warning, flow less GPM at higher RPMs than the stock one.
Old Aug 16, 2011 | 11:35 AM
lt1-xjs's Avatar
Re: 383 overheating
I've ran the CSR ewp for about 8 years without issue. My first pump lasted 4 1/2 years or about 24k miles. I knew two weeks before it failed that it was going to because it made noise. I kept a very close eye on the temp at that point. It will blow the fuse and stop working but I made it home 4 fuses later. I have a spare so in less than 30 minutes I'm back in business. Sent the bad one in for repair and they sent back a new one for like $80.00.
Old Aug 16, 2011 | 11:40 AM
boostedz28lt1's Avatar
Re: 383 overheating
i run the stock unit, i dont want to blow up my engine while driving around town when the EWP goes bad and im looking out the window at some girls asses on the beach. If i were racing and looking for a little more then i would go EWP if im driving on the street Stocker.
Old Aug 16, 2011 | 01:43 PM
Re: 383 overheating
What about the thermostat, should I go with a 160 or 180
Old Aug 16, 2011 | 01:52 PM
WS Sick's Avatar
Re: 383 overheating
Wire in a warning light in your WP circuit and you will know exactly when it pops a fuse.
Old Aug 16, 2011 | 02:27 PM
NJ-LE's Avatar
Re: 383 overheating
Wire in a buzzer along with the light and it will get your attention immediately.
Old Aug 16, 2011 | 07:22 PM
RamAir95TA's Avatar
Re: 383 overheating
The lower temp thermostat won't do you much good without running the fans at the lower temps either by PCM programming or a manual fan switch.
Old Aug 17, 2011 | 09:06 AM
Re: 383 overheating
What about a new radiator? Is there a higher performance one that will fit in the stock housing and keep it cooler
Old Aug 17, 2011 | 01:27 PM
WS Sick's Avatar
Re: 383 overheating
Be cool makes a larger capacity aluminum one, around 600$, My stock one coold my 383 just fine.
Old Aug 17, 2011 | 01:57 PM
mzgp5x's Avatar
Re: 383 overheating
I have a 97 LT1 383 that is FI. I would run in the top range of temp, but get hot when idle. So, I did the following after reading Ray Bohaz cooling systems book.
Had the be-cool 4 core rad.
Moved the rad forward.
Converted to Evans NPG.
No thermostat. Made my own insert to block the bypass.
Run a Mez HD pump.
Run the fans high all the time.
Reduced flow from cylinder head coolant return I think helped with my set-up.
Runs ice cold in 90deg weather. Lower/ below 160 mark on gage when cruzing.
Engine runs very strong, but, I had to flash the PCM to improve the performance. The electric pump option is very easy to turn on/ off and change the WP w/o messing with the mechanical pump drive.
B.
Old Aug 17, 2011 | 02:02 PM
RamAir95TA's Avatar
Re: 383 overheating
The stock radiator is more than capable.
Old Aug 17, 2011 | 02:35 PM
Re: 383 overheating
I guess its getting hot fast because I havnt tried moving it yet, thanks for the help guys
Old Aug 18, 2011 | 01:57 AM
Re: 383 overheating
The cooling problem is fixed, thanks again for all your help
Old Aug 18, 2011 | 08:45 AM
JooneJune's Avatar
Re: 383 overheating
so what was the problem you fixed for the thread followers?
