what is the strongest yr for the LT1's
Old Jan 30, 2003 | 01:07 PM
  #16
Dan95TA's Avatar
Originally posted by DubbyZ28Camaro
How does dual cats gain 10hp??? That is just a restriction in the exhaust flow. Why do you think most people (that are able to) REMOVE their cats to get a little more performance???
actually the design of the dual cat y-pipe flows better than the single cat one. and people take off their cat(s) because it's CHEAPER and/or they don't have emissions. A high flow cat will flow almost as good as no cat but costs alot more than a simple exhaust pipe to delete the cat.
Old Jan 30, 2003 | 01:09 PM
  #17
DubbyZ28Camaro's Avatar
Interesting...thats some food for thought. I don't see how you can get much bigger though than the giant coffee can catalytic convertor that they have on the drivers side...guess I never really looked at the 93-95 Y-pipes before.
Old Jan 30, 2003 | 01:18 PM
  #18
turbo_Z's Avatar
on single-cat cars....the manifolds dump exhaust into the y-pipe as usual and then the y-pipe chokes it down to into a 2.5" pipe before going into the cat.
on our cars the exhaust is already thru the cats before it gets choked down from the y-pipe. thats probably the more important factor.
Old Jan 30, 2003 | 01:24 PM
  #19
'94 Bad A Z28's Avatar
Originally posted by turbo_Z
you would think 97.
-dual cats...freer flowing exhaust
How do you figure that MORE restriction = freer flowing exhaust?
Dual cat's wasn't the reason for the extra 10 hp... Funny a 275hp car will dyno the same as a 285hp car, get that.
-*recently discovered*....heads flow a little better
Same heads as the earlier years, we're not talking about the LT4 here.
-OBD2....might argue it manages fuel more efficiently than OBD1. pure speculation
Just like you said, pure speculation.
-new tail lights and interior...hafta be worth 5 ponies at least!
RICER!!!
Old Jan 30, 2003 | 01:28 PM
  #20
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
dude.... lay down and breathe easy for 10 minutes... take 1 4mm straw from mcdonalds... and see how long you can breathe thru just that... then take two... 3mm straws and repeat...
Old Jan 30, 2003 | 01:33 PM
  #21
scottso's Avatar
1996 Dual Cats
Originally posted by Mikey97Z
I think the 97 was rated at 285hp stock, a 10hp improvement due to the dual cats.
1996 was the first year for dual cats and 285HP
Old Jan 30, 2003 | 01:34 PM
  #22
Re: 1996 Dual Cats
I'm sorry, but late '95s got Dual cats.
Old Jan 30, 2003 | 01:35 PM
  #23
However, they all go back into the same size straw before exiting out at the rear bumper. Anyway, 10hp to me, is no reason to pick one car over another, especially since it is factory published number.
Old Jan 30, 2003 | 01:36 PM
  #24
Re: Re: 1996 Dual Cats
It was California emissions cars that got dual cats in 1995.
Old Jan 30, 2003 | 01:37 PM
  #25
I'm just stating the facts...
  #26
scottso's Avatar
Your right...I do remember reading that. I used to have a 1995 Z28 - build date of 2/1995 and it was single.
Old Jan 30, 2003 | 01:40 PM
  #27
turbo_Z's Avatar
im not talking about LT4 heads. i would refer you to the thread that explains all this in greater detail but youre not really worth my trouble so continue to believe what you want.
Old Jan 30, 2003 | 01:43 PM
  #28
They are the same heads.
Old Jan 30, 2003 | 02:03 PM
  #29
allmotorta's Avatar
No, actually they're not. Some 96 and 97 models got casting # 561 heads which flowed better than the basic LT1 heads. I believe thats what he is talking about.
I don't think any one year stands out as being the "strongest", they all run about the same.
Old Jan 30, 2003 | 02:05 PM
  #30
WS6T3RROR's Avatar
they are not the same heads in the middle of the 96 run they started to use the tooling from the impala heads which flow better than the aluminum heads from 93-95 the casting number for the heads is 561 they have thinner port walls though so when it comes to porting the 93-95 heads they have more potential. yes they're lt1 heads you're right the same... no. everyone knows that on a first gen sbc different castings meant different flow in some cases this is sort of the same thing.
