What spark plugs?
Old Dec 2, 2007 | 07:33 PM
mdacton's Avatar
What spark plugs?
What plug is an autolite racing plug 2 steps colder?
regular is like a 103 I think right? I have no idea...but I need to get a set in the morning.
Stock head castings for LT1
Old Dec 2, 2007 | 07:44 PM
Stock is 106, 104 is anywhere from 1/2 to 1 steps colder than stock (depending what source you believe), 103 is 1-1/2 to 2 steps colder than stock. I run a 104 for NA, 103 for a small (125-150HP) shot of nitrous, and a much colder Champion racing plug for the 300-shot.
Old Dec 2, 2007 | 07:49 PM
mdacton's Avatar
So will that work o.k. using the stock type and not a race type?
The comp is a little over 14 static, I have 103's I can use but was told to use the race plug....I have not a clue what the difference is other then it has half an electrode on it.
And I will be running 112 if it makes a difference
Old Dec 2, 2007 | 08:20 PM
Might want to add all the info with the original question... not many people are able to remember the detailed specs of other's engines. I run 10.8:1, so my experience with plugs would not be applicable to the engine you describe. Someone more knowlegdable in an engine similar to yours will have to help you.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
