what are some good spark plugs and wires?
and where do you get them?
i cannot find any LT1 wires in these damn catalogues like summit and jegs.
where can i get some good wires?
and what plugs do you guys use?
is there anything i should stay away from?
Re: what are some good spark plugs and wires?
I've never heard anything bad about taylors...
I've been running Taylor 8mm spiropro's for um, 5 years now I think.. great wires, fit in the stock looms.
I'll be replacing 'em with a set of OTVC wires shortly, also Taylor's.
NGK TR55's are a good stock / bolt on car plug.
Taylor 8mm spiro-pro wires and AC delco rapidfire #3.
Can get the wires from www.thunderracing.com $49.99
got Taylor 8mm OVC wires and NGK TR55 plugs from thunderracing. both very nice, only thing that sucked a little was crimping and making the ends work with the wires since they were cut to your own length. other than that awesome stuff.
taylors and ngk-tr55's here.....i got the wires from summit racing and i got the plugs from a local shop....i think i paid 45 bucks for the wires and 1.39 a plug.
I wrote a little tech article on wires which can be found at www.kennedysdynotune.com, look in the "Tech Tips" dropdown. I have used the following three brands and think they are all good. I am sure therre are others.
Taylor
MSD
ACCEL
Rich
Taylor
MSD
ACCEL
Rich
I was running Taylor 8mms and NGK TR-55s on my old setup. I have since upgraded to over the valve cover wires from www.elitesparkplugs.com to go with my long tubes. I am still running the NGK plugs though.
I did the ngk tr6's, but you are n/a. so i would do the 55's from NGK, theyre good plugs. Oh, and i would do the MSD 8.5mm super conductor wires, excellent. Victory has both.
Will
Will
