what are some good spark plugs and wires?
Old Feb 22, 2006 | 09:47 PM
cabe_z28's Avatar
and where do you get them?
i cannot find any LT1 wires in these damn catalogues like summit and jegs.
where can i get some good wires?
and what plugs do you guys use?
is there anything i should stay away from?
Old Feb 22, 2006 | 10:01 PM
3gc's Avatar
3gc
Re: what are some good spark plugs and wires?
I read a lot of negative comments about the Taylor wires but i've had good luck with them and a set of NGK TR-55s.
Old Feb 22, 2006 | 10:19 PM
Javier97Z28's Avatar
Moderator
I've never heard anything bad about taylors...
I've been running Taylor 8mm spiropro's for um, 5 years now I think.. great wires, fit in the stock looms.
I'll be replacing 'em with a set of OTVC wires shortly, also Taylor's.
NGK TR55's are a good stock / bolt on car plug.
Old Feb 22, 2006 | 10:24 PM
Temple's Avatar
Taylor 8mm spiro-pro wires and AC delco rapidfire #3.
Can get the wires from www.thunderracing.com $49.99
Old Feb 22, 2006 | 10:25 PM
RicocheT's Avatar
I like the msd wires myself, run them and a set of autolights
Old Feb 22, 2006 | 10:29 PM
69z-28's Avatar
got Taylor 8mm OVC wires and NGK TR55 plugs from thunderracing. both very nice, only thing that sucked a little was crimping and making the ends work with the wires since they were cut to your own length. other than that awesome stuff.
Old Feb 23, 2006 | 10:15 AM
Eddie Z-28's Avatar
I use the MSD Super Conductors and NGK's and they are great!
Old Feb 23, 2006 | 12:07 PM
Schweet97Z's Avatar
taylors and ngk-tr55's here.....i got the wires from summit racing and i got the plugs from a local shop....i think i paid 45 bucks for the wires and 1.39 a plug.
Old Feb 23, 2006 | 12:11 PM
Joe B's Avatar
I've had the best luck with the MSD's .....and autolite's
Old Feb 23, 2006 | 12:22 PM
firebirdStud's Avatar
I had two sets of taylors arc, MSD's fixed it 90 percent, and I am going with elitesparkplugs.com this spring. GM rapidfires are the shizznit!
Old Feb 23, 2006 | 02:18 PM
rskrause's Avatar
Moderator
I wrote a little tech article on wires which can be found at www.kennedysdynotune.com, look in the "Tech Tips" dropdown. I have used the following three brands and think they are all good. I am sure therre are others.
Taylor
MSD
ACCEL
Rich
Old Feb 23, 2006 | 02:20 PM
Cmr0z28's Avatar
Taylor 8mm wires. NGK TR55s if you have bolt-ons, Autolite 104s if you're making decent power / spraying.
Old Feb 23, 2006 | 03:25 PM
blue's Avatar
That is helpful. I'm a little surprised that a higher pressure mixture in the cylinder will have higher resistivity but now I know why ignition systems need to be upgraded. But why not just use a smaller gap in the plugs instead of upping the voltage through coil and wires? It would be cheaper.
Old Feb 23, 2006 | 03:39 PM
2000GTP's Avatar
I was running Taylor 8mms and NGK TR-55s on my old setup. I have since upgraded to over the valve cover wires from www.elitesparkplugs.com to go with my long tubes. I am still running the NGK plugs though.
Old Feb 23, 2006 | 03:50 PM
hulettsz28's Avatar
I did the ngk tr6's, but you are n/a. so i would do the 55's from NGK, theyre good plugs. Oh, and i would do the MSD 8.5mm super conductor wires, excellent. Victory has both.
Will
