what size rings to run
Old Sep 27, 2004 | 11:31 PM
92rslt1's Avatar
what are the sizes of a lt1 engines rings??
Old Sep 28, 2004 | 07:45 PM
5.7LT1Formula's Avatar
Re: what size rings to run
ring size will have to do with Bore and size of your piston..if you have a .030 bore..you'll need a .030 piston w/ standard rings...on some pistions you may need to file fit your rings (which is a pain..i had a machine shop do mine)
Old Sep 28, 2004 | 07:55 PM
arnie's Avatar
I trust you are referring to ring widths (or thickness). AFAIK, the sizes are 2 mm., 1.5 mm, and the oil ring is 3.8 mm.
Old Sep 28, 2004 | 08:55 PM
1racerdude's Avatar
If you get aftermarket pistons get 1/16--1/16--3/16 they are the most common and cheapest.
Old Sep 28, 2004 | 10:19 PM
92rslt1's Avatar
are these rings hard to find in mm sizes?
Old Sep 28, 2004 | 10:29 PM
1racerdude's Avatar
Shouldn't be.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
1963SS
Feb 6, 2015 10:05 AM
1775.Z28
Jan 11, 2015 10:51 AM
