what size puller for crank pulley?
Old Jul 23, 2004 | 07:16 AM
94Zpower's Avatar
About to to my opti swap and was wondering what size puller I will need for the crank pulley??
Thanks!
Old Jul 23, 2004 | 07:25 AM
GetaZforgetGT's Avatar
Re: what size puller for crank pulley?
I think mine maxes out at 4". I got mine from Sears. Its the one that can be a two jaw or a three jaw puller in case you need a visual on it.
Old Jul 23, 2004 | 08:12 AM
TransAmGT's Avatar
You don't really need one...just did my brother's opti last night...and done several before...just soak it in PB blaster, or some lube then hit it with a hammer on both end untill it wiggles off...good luck!
Old Jul 23, 2004 | 10:14 AM
94Zpower's Avatar
Cool thanks guys! now I have ways to get it off if one dosent work!
In quebec we have a joke about using hammers! a hammer is called a French screw driver!!lol if it dosent come of witht he srew driver use the hammer.
Old Jul 23, 2004 | 10:38 AM
In theory, it comes right off, as noted above. If you hammer, do not hammer on the outer edge... you can break the pulley edge, or the rubber ring that connects the outer ring to the inner ring. If you have to "pull", use a puller that can pull on the inside ring, not the outside ring - same reason.
As usual, you can find the answer to a lot of these questions on Shoebox's Tech Pages:
http://shbox.com/1/pull_pulley.jpg
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Rde Bandit
Mar 21, 2015 10:17 PM
