What size is the mian pipe running to the muffler?
Old Feb 9, 2004 | 11:23 AM
JONEZ_Z's Avatar
I am going to get an electric cutout from DMH perfromance and im afraid if i get one for the stock size pipe that i will be screwed later if i get a catback that has a larger diameter pipe. What do you guys think? Thanks
Old Feb 9, 2004 | 11:27 AM
teke184's Avatar
2.75"
the standard 3" unit will work perfect.
Old Feb 9, 2004 | 11:33 AM
JONEZ_Z's Avatar
If i decide to get a catback later, arent they larger though? Like the Hooker Catback? THen i will need a new 200.00 cutout. Or are they the same size?
Old Feb 9, 2004 | 11:55 AM
teke184's Avatar
most catbacks (except mufflex 3.5" and 4") are 3", meaning you can just cut the cutout off and reweld it to the catback.
and realize that the $200 goes to the electric cutout motor and mounting plate.
the cutout itself is only $35 from summit or jegs. so you could easily replace that with the new exhaust and bolt the electric plate up to it...
this is what the e-cutout plate looks like (this happens to be my QTP...but it should be similar), which is the majority of the cost for an e-cutout
this is what the actual cutout will look like
Old Feb 9, 2004 | 12:57 PM
JONEZ_Z's Avatar
Hey teke184, thanks thats all i needed to know. I appreciate it.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
alphaauto
Jan 22, 2015 08:02 PM
