what size bolt
Old May 8, 2004 | 12:01 PM
TrouserSnake's Avatar
what size bolt
To push off the crank to get the harmonic balancer off again
Old May 8, 2004 | 12:02 PM
The ones with the harmonic balancer set just shredded and bent to Fahk
Old May 8, 2004 | 01:11 PM
I assume you are trying to get the Opti off so you can check the orientation of the splined shaft, as suggested in another thread. You only need to take the damper/pulley off the hub. Since you just had it all apart, why would it be that difficult to pull the damper/pulley off.... it should fall off when you take the 3 bolts out????
Or do you have some reason for pulling the entire damper and hub?
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Red97LT1
Mar 1, 2015 05:08 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
