Need header plugs for AIR tube holes
Old May 5, 2004 | 12:08 PM
Pony Punisher II's Avatar
I've removed the AIR injection from my 95LT1 Trans Am. It has the BBK headers which have outlets for the AIR tube to screw in. I need a plug or bolt that will fit the threads. Anyone know what size I need, and where to order it from?
Jason
Old May 5, 2004 | 12:16 PM
drewstealth's Avatar
i think its a 22mm plug. But i'm not totally sure.
Old May 5, 2004 | 12:34 PM
wiked95ta's Avatar
it is, good luck finding one that size. hehehe you can search for 22m drain plug on google and find a vender that way
Old May 6, 2004 | 06:35 PM
Anyone else? I'm sure I'm not the only one to run into this.
Old May 7, 2004 | 01:39 AM
Lower's Avatar
This website is often given out:
http://www.cgenterprises.com/drain_plugs_metric.htm
Although you should be able to find them locally. Hit a random quickie oil change place, and ask them for oil drain plugs in the size you need.
Better double check the threads here to make sure the BBK headers take a 22mm before shopping for them.
Old May 7, 2004 | 07:29 AM
Crankshaft's Avatar
Napa has them, they're around ~9 a piece. M22 (BMW) oil drain plug.
Old May 7, 2004 | 10:56 AM
I believe they are M22 x 1.50. I guess I'll order a set from CG Enterprises in Canadia
thanks
Old May 7, 2004 | 11:07 AM
I paid $2.50 each for M22-1.5 oil drain plugs, plus 98-cents for a couple of copper washer to seal them.
On the remote chance that your 95 is a "CA emissions" A4, it will have the M18 threads that were used in the 96/97 dual cat cars, rather than the M22's for the single cat cars.
Measure the fittings you unscrewed from the headers. If they are about 7/8" diameter, they are M22. If they are closer to 11/16", they are M18.
Old May 7, 2004 | 11:49 AM
RealQuick's Avatar
yup. 7.50 a piece for mine.
Old May 7, 2004 | 07:57 PM
Well, I got a thread guage, and it turns out that it is NOT metric. I measured the diameter with a micrometer.
The actual size is: 7/8" x 18 thread pitch, which is very close to 22mm x 1.50. So, I ordered 2 from CG enterprises for $5.95 each.
Thanks anyway
Old May 8, 2004 | 11:32 AM
RealQuick's Avatar
Thanks anyway
I would double check your gauge. i used english threads before and I had to use wrench to crank them in and out. i popped in the metric ones after and I could thread them in by hand.
Old May 8, 2004 | 11:39 AM
Dave Feerst's Avatar
somone told me 7/8 but i could not get them to go in so I went and got the 22 / 1.5 from napa for like 3$ and they worked great with come copper washers.
Old May 8, 2004 | 01:08 PM
The guage was right - I double and triple checked.. I'll post up whether or not they fit right. I even tried the 1.5 thread guage, and it was clearly off. The 18 guage fit perfectly, though. We'll see in about 1 week or so.
Old May 8, 2004 | 01:16 PM
When I pulled the AIR connections out of my AS&M's, they were so tight they were deforming inside the wrench - and they had only been in there for a few months. When I then screwed the M22-1.5 plugs in, they fit perfectly, with no binding. If they are the wrong size, they are a pretty decent substitute... but do it any way you want to, its your car.
95chwagon
Jan 13, 2015 09:19 PM
CobraEatr
Jul 24, 2004 11:37 AM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
