What are signs of a vacuum leak
I was just wondering what are signs of a vacuum leak and how do you diagnose it as well as fix it?
I have no indication my Z other than bad gas mileage. The car runs great but my economy sucks.
Re: What are signs of a vacuum leak
Everything on my car has been changed within the last 5-10k miles, except the opti and coil but the ignition system seems to be working fine. Car idles normally.
Put a scanner on it and check the LTFTs. I pulled the opti vent hose off the manifold just to see what it would show on the scanner. The LTFTs shot up to like +20 or sumin like that.
As others said, if its a decently sized vacuum leak the idle will be very irradict and the car will generally run like crap. If its just bad gas mileage, it could very well be o2's, dirty air filter etc....
14
Aug 11, 2015 12:03 PM
whitehooptie
Jul 12, 2015 06:10 PM
