What is on the Side of the heads
Old Oct 28, 2003 | 05:41 PM
Camaroz28lt1383's Avatar
I know the hole on the side of the driverside head is for the coolant temp sensor, but what is the hole on the pass. side for? I had my heads ported and left the 2 things in the heads, and didnt get them back. Thanks Paul
Old Oct 28, 2003 | 05:56 PM
klbjoc's Avatar
You just need to plug the passenger side hole.
Old Oct 28, 2003 | 05:57 PM
Stoopalini's Avatar
The pass side hole is also for the coolant temp sensor. Think about it, the heads are identicle, so if you swapped them from side to side, the hole would need to be there.
Thomas.
Old Oct 28, 2003 | 07:58 PM
NOMAD's Avatar
Thomas.
Same reason there are 2 holes plugged in the front, so you can swap sides and still retain the reverse flow cooling
-Shannon
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Rod Bender
Jan 1, 2015 03:18 PM
