What should i run stock?
Old Mar 23, 2004 | 03:58 PM
got8?'s Avatar
Question What should i run stock?
What should i run with a stock 97 z28 with a little under 100,000 miles?
Old Mar 23, 2004 | 03:59 PM
re1080's Avatar
i would say low to mid 14s depending on how often youve been to the track if its your first time expect mid 14s
Old Mar 23, 2004 | 04:02 PM
got8?'s Avatar
well i have been to the track a bunch before but it was with my 94 3.4 v6 camaro haha it was a good learners car for rear wheel drive my best friend has a 2002 mustang gt with a 5spd and i usualy and a half a car lenght beside him
Old Mar 23, 2004 | 05:08 PM
Zigroid's Avatar
When my car was completely stock with about 110k miles on it I ran a 14.8@93 best.
This year I went back to the strip. I learned how to launch it, removed spare tire and jack, and installed an SLP cold air intake and I dropped my best down to a 14.4@97 with a 2.1 60' time. My car is kind of tired because of the high mileage though . You should run a comparable time to my 2nd time or maybe a little better.
Old Mar 23, 2004 | 05:22 PM
mebanditws6's Avatar
If your car is in good condition and assuming everything is running ok, it's capable of high 13's trapping a hair under 100mph, a little faster if it's a 6spd. Do a search for stock 1/4 times. That will answer your question better.
Jason
Old Mar 23, 2004 | 06:09 PM
stereomandan's Avatar
Cool name by the way.
I had never been to the track, but had driven my '97 for 6 years and thought that I could drive it well.
The track is much different than the street. I've only been to the track once so far. My best was 14.4@98 stock with a 2.2 60'. The weather was terrible for times though. 86 deg, 80% humidity. I was hoping to break into the 13's, but was disappointed. I think with cooler, dryer weather, that run would have been about 14.0@100 easy.
Anyways, the track prep was so good that I kept bogging the engine. With the amount of gas I gave it, I would have normally had a little slip off the line. Not with the sticky track. Be careful of that, depending on how good the track is.(and whether you have an M6 or A4)
I also think that you'll run 14.0 - 14.6 @96-98. With good weather, like we have this time of year, you may break into the 13's. This is all assuming that the car is running well.
Good luck!
Dan
Old Mar 23, 2004 | 06:42 PM
My95Z's Avatar
right aroun 13.9 or 14 if you can drive good
DirtyDaveW
Dec 1, 2016 05:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Dec 27, 2014 10:06 AM
