what should I leave off for my header install?
Old Mar 8, 2004 | 10:58 AM
Zack's Avatar
i replaced a blown head gasket, and am beginning to put everything back on. What should I leave off that will make the header install easier?
Old Mar 8, 2004 | 11:03 AM
soontobeGN's Avatar
starter, steering linkage, alternator, valve covers, power steering pump, ASR box if you have one........
anyone else wanna add anything?
Old Mar 8, 2004 | 11:09 AM
ibanez6rg's Avatar
Dipstick.
[edit] I installed my LT's with only the dipstick, starter, and alternator removed.
Old Mar 8, 2004 | 11:12 AM
Red96Lt1's Avatar
The power steering pump isn't necessary. You might have to take the passenger side motor mount loose.
Old Mar 8, 2004 | 11:20 AM
soontobeGN's Avatar
they are right, only alternator, dipstick and started are required, but you will find that removing as much as possible in the beginning will make your life much easier in the end. its a lot easier to get to the first bolt on the passenger side with the power steering pump out. trust me, leave everything you can out.
Old Mar 9, 2004 | 12:40 AM
Zack's Avatar
i never took the PS pump out to begin with
Old Mar 9, 2004 | 01:02 AM
Red_94Formula's Avatar
Drop the k-frame and they will slip right in. Get a light weight k-frame.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
GigaMp3z
Feb 20, 2003 02:57 PM
