What should i buy first..HEADS or HEADERS.
Old Feb 11, 2004 | 05:39 AM
Reptile5.7L's Avatar
im a little comfused, what u guys think i should buy first Hooker headers long tubes or a set of new performance heads for my 1994 trans am LT1 ,shes stock, all shes got is a flowmaster series 40 mufler and a new KNK fuel injection ram sistem,sucks air from botom 8-(. but i did noticed the dif from the day i installed it even at top speeds,gets there faster and acelerates much faster too, not a bad way to spend 200 bucks,and another 155 for the flowmaster 8-)
Old Feb 11, 2004 | 05:42 AM
scoobysnax83's Avatar
Headers for sure, Stock Manifolds flow like crap! If you got heads you wouldn't be able to fully utilize them.
Old Feb 11, 2004 | 06:33 AM
whatsup's Avatar
Headers for sure first....I wouldn't consider heads until you can use their benefits. I would go with gears next (you said stock so I'm assuming everything is stock) if its an auto then a converter would be my next mod then probably a cam set AND THEN start looking into heads.
Old Feb 11, 2004 | 06:55 AM
Derrick Redd's Avatar
I agree with headers also.
Old Feb 11, 2004 | 07:02 AM
Bastardcat's Avatar
I'm with these guys--go with headers. You have to get 'er breathing better to start out.
Old Feb 11, 2004 | 07:31 AM
ibanez6rg's Avatar
Headers.
Brandon94Z28's Avatar
Not even a question, go with headers. Heads and cam come after all the bolt ons
Brandon
Old Feb 11, 2004 | 07:43 AM
Fastbird93's Avatar
THink of it this way. It makes no sense to bring in a ton more air if you can't expel that air equally as fast.
Headers.
Old Feb 11, 2004 | 07:46 AM
mongse_1's Avatar
Headers without a doubt. I wouldn't consider heads until you've done all the bolt-ons and suspension work.
Old Feb 11, 2004 | 07:50 AM
besz28's Avatar
get the headers,some more bolt ons then get serious
Old Feb 11, 2004 | 09:05 AM
IDOXLR8's Avatar
Another vote for headers first.
Old Feb 11, 2004 | 11:07 AM
SBCGENII's Avatar
headers and boltons first, otherwise just wasting money
Old Feb 11, 2004 | 11:12 AM
drewstealth's Avatar
Headers first. You would be disapointed with the gain you felt with the heads without the headers.
Old Feb 11, 2004 | 11:13 AM
SScamaro463's Avatar
got have the flow 1st man
Old Feb 11, 2004 | 12:21 PM
GreenDemon's Avatar
Headers.
Even though in the end the heads will show larger gains than the headers probably will, you won't see those gains without freeing up your intake and exhaust first. You've gotta do the outside before you can start working on the big stuff. - And I'd do heads and cam at the same time, if you want to do heads and you've got the dough- you'll need a bigger cam in there to utilize the extra flow the heads will be giving you.
