What shaft mounts are you running?
Old Nov 18, 2007 | 06:17 PM
mdacton's Avatar
I am running stud mounts and a girdle.....this stuff has got to go. Everytime I adjust the valve then tighten the girdle it moves the stud and my lash changes.
It is also a huge pita to mess with. So I will run what I have for now...but want some shafts soon.
What are my options and how do you like them?
t&d? jesel?
Old Nov 18, 2007 | 06:29 PM
Projectz28's Avatar
Moderator
Running the Jessel SS rockers. I line em. The only problem I ran into was that they don't fit over the ARP head studs. They come with new low profile bolts with a Torx head and they do supply the tools also. I am running +.100 valves and with them you install a supplied shim under the stands. With them the rocker stands almost clear the studs. I honestly could have probaby made the studs work by pulling them and machining off some of the tops of them... I opted to just use the ARP bolts they gave me.
I hear the T&D's work with studs... not sure though. They are more expensive, I went with the Jessels that my machine shop recommended.
Old Nov 18, 2007 | 06:35 PM
mdacton's Avatar
I didn't use studs anyway, can I get the SS series in a 1.5/1.6 ratio?
Old Nov 18, 2007 | 06:47 PM
Projectz28's Avatar
Moderator
Sure. 1.5's, 1.5/1.6 combo or 1.6
Old Nov 18, 2007 | 08:20 PM
cdb95z28's Avatar
I have the Jesel SS also. 1.6/1.6. On my 190cc AFRs everything fit good and my Proform valve covers cleared them too.
Old Nov 18, 2007 | 08:54 PM
walt355's Avatar
Damn I just bought a set of Crower 1.6 rockers and a set of stud girdles, Are they really that much PITA? I got these at a deal so Im not that worried. Didnt have the $$$ for a good shaft mount set up
Old Nov 19, 2007 | 12:01 AM
NJLT1SS's Avatar
Jesel SS shafts here. I will never use a stud mount again.
Nick
Old Nov 19, 2007 | 08:27 AM
Z-RATED94's Avatar
Nick
So how much are we talking about here, for the Jesels?
Old Nov 19, 2007 | 08:28 AM
Javier97Z28's Avatar
Moderator
A quick peak at Jegs shows about $900 for the setup.
Old Nov 19, 2007 | 08:29 AM
Z-RATED94's Avatar
Thank you.
Old Nov 19, 2007 | 09:47 AM
Projectz28's Avatar
Moderator
depends on which ones you get. The Sportsman series run about $795. If you shop around you can get them just a tad cheaper at around $780 ish. At least thats what I paid last year for them...
Old Nov 19, 2007 | 06:29 PM
cdb95z28's Avatar
Same here. The durability and ease is worth the extra money
I got mine from Scoggin-Dickey in April, part # KSS336060:
$775.00
Shop around, there is a large price spread on the same part #s
Old Nov 19, 2007 | 08:42 PM
mrz28 73/97's Avatar
Hey mdaction something quick on adjusting your valves with the stud girdle, I was having the same problem and what I found to work was to set the lash and tighten the poly lock until I could barely pull out the feeler gauge then tighten the stud girdle and rechecked the lash and it would come out perfect.
importkiller94
Jan 17, 2015 09:03 PM
importkiller94
Parts Wanted
Jan 17, 2015 07:23 PM
Cam's maro
Dec 28, 2014 09:30 AM
Absolute Z28
Jul 19, 2002 02:21 PM
