what seal is this?????
Old May 11, 2005 | 05:57 PM
96 trans am's Avatar
Question what seal is this?????
Well I have taken my air pump off, water pump, opti, hoses, and a few other things. I'm trying to find out what the seal behind the opti is called so I can replaced all the seals while I have all of this off. Also I want to clean it up a bit, so what is the best stuff to use to clean your engine and parts???? Any help I would appreciate. Thanks
Old May 11, 2005 | 07:55 PM
Deenasty's Avatar
Re: what seal is this?????
do you mean the rubber o-rings on the opti shaft? Or the seal on the opti shaft, that is on the timing cover?
Old May 11, 2005 | 08:05 PM
BadBowS10's Avatar
if you order a timing cover gasket set it will come with all the seals and such that you need
greg
Old May 12, 2005 | 11:56 AM
it is the seal in the timing cover where the opti goes, I called a dealership around here and they gave me this part number 12552428, is this the right part number????
Old May 12, 2005 | 12:17 PM
sssalah's Avatar
Yes, that's the right pn for a 95-97 for the distributor driive shaft that fits in the timing cover.
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Bails098
Aug 17, 2015 05:15 PM
