What rpm should my car idle at?
Old Apr 14, 2006 | 12:04 PM
danny525's Avatar
Question What rpm should my car idle at?
96 a4, once warm, it idles at around 600, seems low, my 95 m6 idles at 1000, just seeing if the auto is out a bit, and where is the idle speed adjustment screw?
Old Apr 14, 2006 | 12:15 PM
hotrod18_69's Avatar
Re: What rpm should my car idle at?
That is normal.. A4 idle around 550-600 M6's are around 800-900 Its how there are programed from the factory.. Adjusting the screw wont help.. The IAC valve will just compensate for it..
Old Apr 14, 2006 | 04:20 PM
DIYAR21's Avatar
my A4 idles right on 1000 RPM. all the time.. do u have missfire on your A4?
Old Apr 14, 2006 | 04:27 PM
Factory programming, coolant fully warmed up:
A4:
-In neutral: 650rpm
-In drive: 550rpm
M6:
-All: 800rpm
Remember, the factory tach seems to read 100-200rpm higher than the actual idle speed. A "scanner" will let you read the correct rpm from the PCM.
Old Apr 14, 2006 | 04:51 PM
chas's Avatar
My 97 Z28 runs at 700rpms!
Chas
Old Apr 15, 2006 | 08:34 AM
Chas
A4 or M6? Reading from the tach, or from a scanner on the PCM?
Old Apr 15, 2006 | 08:57 AM
BlackScreaminMachine's Avatar
with tuning my a4 is 900-1000 via datamaster
Old Apr 15, 2006 | 07:24 PM
DIYAR21's Avatar
A4:
-In neutral: 650rpm
-In drive: 550rpm
M6:
-All: 800rpm
my 97 A4 formula idles right on 1000 rpm... in N and D. all..
Old Apr 15, 2006 | 08:16 PM
chas's Avatar
Its a auto and reading on the tak, i will recheck it just to make sure.
Chas
Old Apr 16, 2006 | 11:49 AM
I can only tell you what the stock programming is.
Old Apr 16, 2006 | 01:15 PM
DIYAR21's Avatar
my point is, do u guys think something is wrong with my car or it is better for the car? since l got the car, it is like tat.. also sometimes on park it idles 1200 RPM. and goes back to 1000 RPM.
Old Apr 17, 2006 | 12:33 AM
Has the PCM been reprogrammed for any reason? Hard to tell from your signature what the car has in the way of mods.
IF its idling at anything higher than the stock programming, there's a problem. Higher idle does not help anything. Just helps heat up the tranny fluid. You need to get a scanner on it and see what the idle air control (IAC) motor counts are. If they are at "0" and the idle is 1,000rpm, you've probably got a vacuum leak, or the IAC motor is deceased.
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
