What rpm should my A4 be shifting at?
Old Sep 2, 2003 | 04:43 PM
TenaciousZ's Avatar
at a WOT run from 1-2 2-3 3-4? anyone know where I can find any place that could tell me?
Old Sep 2, 2003 | 05:57 PM
ramair94ta's Avatar
from 1st to 2nd it shift at 6500-6700rpm, not sure about the other gears , ive only had the car for a few weeks.
Old Sep 2, 2003 | 06:10 PM
TenaciousZ's Avatar
thanks , maybe it's me but that seems high
Old Sep 2, 2003 | 06:16 PM
ramair94ta's Avatar
I thought it was high to and was going to post about it but i forgot. It seems to die in power in the top end like it hold the gear to long.
Old Sep 2, 2003 | 06:20 PM
TenaciousZ's Avatar
hmm hopefully somebody who knows can shed some insight on this
Old Sep 2, 2003 | 07:14 PM
revtime's Avatar
You had your PCM reprogrammed it says in your sig so call Bryan and ask him where he set it at.
Ed Wright did mine and its shifting at about 5800 or 5900, thats whats showing on the stock tach so who knows if its right.
I don,t remember what Ed told me he programmed it for, it was like 4 years ago.
I know my factory rev limiter is set at 6500 rpm and I have my accel 300+ set at 6250.
Old Sep 2, 2003 | 08:26 PM
97Z-M6's Avatar
not trying to be a$$ but but the factory rev limit is not 6500 hundred itsd about 5850, maybe thats what it was when you bought it. but not factory.
Old Sep 2, 2003 | 08:58 PM
revtime's Avatar
You are exactly right.
I had the stock rev limit upped to 6500 with programming so I could use the 300+ as my rev limiter.
Sorry, I should have been more specific.
Old Sep 2, 2003 | 09:34 PM
Geezer powered's Avatar
stock shift points are 5700 1-2 5700 2-3 3-4 5500 under wot.Stock rev limiter is set at 5800
Old Sep 2, 2003 | 09:39 PM
Re: What rpm should my A4 be shifting at?
It shifts per tables in the pcm. Find out from your programmer what they are set to.
Old Sep 2, 2003 | 11:09 PM
ramair94ta's Avatar
my car is stock with a rebuilt trans and shift kit and it holds gears to 6500 with no rev limit. how is this.
Old Sep 2, 2003 | 11:47 PM
Dan K's Avatar
Pointless. A stock LT1 is done by 5800.
Old Sep 3, 2003 | 12:30 AM
94formulabz's Avatar
http://www.personal.psu.edu/users/b/...dyno/DYNO2.jpg
Here is a stock heads cam and manifolds LT1 dyno. 5800 IS the perfect shift point fo0r a M6. For an auto which is going to lose more rpm on the shift i could see spinning to 6000, but certianly not 6500. Check your tach maybe by using a scanner or get an after market tach. It certainly wasn't intended to hold it to 6500 from the factory.
-brent
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
Apr 16, 2015 09:57 AM
jb4xx
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
