Front End Squeals/Squeaks-No glove box data tag
Old Sep 2, 2003 | 09:29 PM
MuffZ28's Avatar
After my car has warmed up, it tends to squeal when I turn the wheel. There's no grease fittings on the front end. What could be the prob?
Old Sep 2, 2003 | 09:32 PM
Squeal how and when doing exactly what? Need more details.
If you are looking for RPO codes, try the driver's door. They used that location in later years.
Old Sep 2, 2003 | 11:14 PM
MuffZ28's Avatar
It's more of a howl I guess. Kinda' like a pump sound{its not}, rubbing tires {its not}Wheel bearings felt good last time it was in the air. What are the possibilities? I'm hard of hearing, so this is killing me.
Old Sep 2, 2003 | 11:40 PM
If it is a squeal that is rotational in nature, it just about has to be the bearings (assuming no tire rubbing). If it is a vibration, it could be tires. You could rotate them to see if anything changes. I am also assuming the noise is not coming from the power steering pump.
Old Sep 3, 2003 | 12:32 AM
Lost's Avatar
If it makes a whining when you crank the wheel it's probably low on power steering fluid as Shoebox said. You also said your hard of hearing.. me too.. sure it's not the belt or a bearing on a pulley? I know how hard it is to figure out where the sound is in fact coming from and how it sounds different for you and I probably than it does for others
Good luck tracking it down.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
redleader
Jan 22, 2015 10:11 PM
x7x7
Aug 15, 2002 06:49 PM
