What rod bolts besides ARPs?
Old Feb 8, 2005 | 03:08 PM
Pasky's Avatar
I just can't see spending $60 on bolts, don't care if you call me a cheap ***. Just wondering if someone can tell me the sizes and what to use (stud, nut, etc...) so I can go get some grade 10 bad boys on it.
Old Feb 8, 2005 | 03:27 PM
rskrause's Avatar
Moderator
Re: What rod bolts besides ARPs?
ARP's are ~<$50 from Jegs, Summit, SDPC etc.
Rich
Old Feb 8, 2005 | 03:54 PM
Pasky's Avatar
*sigh*, I can get a handful of grade 10's for $7... Don't feel like paying $50 in bolts because they say ARP. If its a stupid idea say so, but if a regular ole' bolt and nut will work, screw ARP
Old Feb 8, 2005 | 03:59 PM
chevyguy3's Avatar
umm, maybe in other areas that may be true, but you are insane if you are even thinking of using Grade 8 bolts from a hardware store for rod bolts
Old Feb 8, 2005 | 04:11 PM
Pasky's Avatar
Alrighty, I have no idea if this could be done, which is why im asking. So I take it rod bolts have some sort of special fitting or something???? Im not trying to be a smart ***, im sincerely asking why it isn't a good idea.
Old Feb 8, 2005 | 08:48 PM
1racerdude's Avatar
Rod bolts are rod bolts.Grade 10 cap screws or bolts and nuts are nuts and bolts.
Rod bolts are made to FIT a rod and have the proper HEAD to fit a rod and the proper STREACH to hold a rod and cap together and the proper size to ALIGN the cap and rod.
Be advised that after installing new rod bolts the rods HAVE to be resized by a machine shop.
Old Feb 8, 2005 | 09:36 PM
rskrause's Avatar
Moderator
The fit issues as described above are vital. Also consider rod bolts = the highest stress fasteners on a car. .
Material/Yield Strength/Tensile Strength/Use
Grade 5/90,000psi/120,000psi/Accessory bolts and studs
Grade 8/120,000psi/150,000psi/Accessory bolts and studs
"Stainless 300"/140,000psi/170,000psi/Accessory bolts & studs, head studs
Custom 450®/150,000psi/180,000psi/Head bolts, accessory bolts
8740 chrome moly/160,000psi/190,000psi/Rod bolts, head & main studs & bolts
A286/170,000psi/200,000psi/Head bolts, accessory bolts
ARP®2000/180,000psi/215,000-220,000psi/Connecting rod bolts
L19/200,000-230,000psi/230,000-260,000psi/Connecting rod bolts
Inconel 718/190-210,000psi/220-240,000psi/Connecting rod bolts
Custom Age 625+/235-255,000psi/250-280,000psi/Head studs, connecting rod bolts
ARP® 3.5/220-250,000psi/250-280,000psi/Connecting rod bolts
AerMet® 100/258,500psi/300,000psi/Connecting rod bolts
8740 is the minimal material you should consider for rod bolts. It is ~33% stronger than Grade 8. I get warm and fuzzies thinking about my ARP 3.5 bolts!!!
Rich
Old Feb 8, 2005 | 11:38 PM
SStrokerAce's Avatar
Rich
Good post Rich I was just about to do that!!!!
I'll put it this way.....
That $50 you save on the Grade 8's at the hardware store.... well I'm going to just put a conservative guess that they are going to cost you a full rebuild or a whole motor. So go look on ebay or call a local yard and ask what a LT1 Long Block runs for now, cause that's what it's going to cost when that grade 8 bolt goes..... because i'm 100% sure it will.... and you loose... a set of valves, a rod definately, a crank, a piston and probably get a big dam hole in the block or the pan.
A ROB BOLT IS THE HIGHEST STREESSED PART IN A ENGINE PERIOD. These are parts that aren't aircraft quality, they are better. You know that Ford commercial with a F150 hanging from a bolt they use in the frame on the truck, well that thing is comparable to a poodle and a rod bolt is closer to ohhhhh King Kong. Something like a Pro Stock rod bolt or F1 rod bolt is probably one if not thee highest stressed bolt in the world.
If you do go with the grade 8's start a poll on here for how long it's going to last. I'm in on that with lots of money.
I don't want to sound like I'm picking on you, but a grade 8 bolt in a rod is THE DUMBEST MISTAKE YOU CAN DO in a engine. Mostly because a set of ARP's is fool proof if you can use the lube that comes with it and a decent TQ wrench.
Bret
Old Feb 8, 2005 | 11:40 PM
My bad grade 10, well you might get down to the store and back with that. At least it gets out of the driveway.
Bret
Old Feb 8, 2005 | 11:45 PM
Pasky's Avatar
Bret
Which is exactly why I asked, thanks.
Old Feb 16, 2005 | 01:11 PM
Pasky's Avatar
I feel like such a dumbass, I never realized these were pressed on. Forgive my stupidity. Never took time to look at them.
Old Feb 16, 2005 | 01:17 PM
Pasky's Avatar
Ok, quick question. Last night I was looking for my rod nuts (my garage is a mess with all the parts lying around) and couldn't find them. Can I use a regular nut or is this thing also very high strentgh? If not, guess i'll be searching through my garage or going to the dealer. THanks.
Old Feb 16, 2005 | 01:29 PM
96m6lt1's Avatar
hey pasky go through the garage with a telescoping magnet and find that nut or just run to the dealer and get one or better yet if you have some x-tra cash buy a set of arps and have the rods resized.......its worth it bro.
Old Feb 17, 2005 | 08:43 PM
LT4orbust's Avatar
yes, that nut is just as important as the bolt
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
