What rim should i mount Slicks on?
this is were i know little info about.
What rims to mount slick tires.
I want to get a pair of 16" salad shooters cause they are cheap as dirt, but what is the max size slick could i mount to that.
Also i want slicks, not no stinkin drag radial.
THE STICKY ICKY STUFF .
Also I'm getting a Moser 9" anyday now
I see a common height would be 28x11.5x16 micky thompsons
What benifits would 14" or 15" or 16" or 17" rims over each other and what rim width would i need for a 10. or 11.5 tire?
Well, the smaller the rim size the more sidewall you can have on the tire and more flex it will allow. Most get a 15'' rim and the widths will vary but you can fir a 10'' slick on a 8'' rim or wider.
Re: What rim should i mount Slicks on?
If you are planning on mounting a good tire on your car then I would recommend going with a 26x11.5x16 MT Steet ET.
Just remember whenever you run a sticky tire you run a chance of blowing up your rearend.
Re: Re: What rim should i mount Slicks on?
Rich Krause
RUENUF
Mar 13, 2016 03:37 PM
Cbr02
Aug 24, 2015 07:12 AM
