What removes carbon buildup?
Old Oct 23, 2003 | 09:40 PM
SMOKNZ's Avatar
Just wondering what works good for removing carbon buildup on the combustion chambers and also the pistons. I have my heads off the car and would like to clean then up.
Bill
Old Oct 23, 2003 | 09:48 PM
BlkZ28M6's Avatar
don't know if the motor is out but take it to a machine shop and have the motor honed and hot tanked. I would have the pistons hot tanked also seperatly
Good Luck
Old Oct 23, 2003 | 10:04 PM
unvc92camarors's Avatar
seafoam removes carbon and all that
do a search, too many topics on it to count
Old Oct 23, 2003 | 10:27 PM
NewbieWar's Avatar
yea but seafoam u must use while car is on, so that kinda is pointless when hes got his engine apart.
Old Oct 23, 2003 | 10:32 PM
turbo_Z's Avatar
any decent degreaser you can get your hands on and a wire brush is all id think youll need.
Old Oct 23, 2003 | 11:05 PM
FastZinTennessee's Avatar
Ok I think I get it. You have the heads off, and motor waiting for the heads to be put back on, and wanting to clean in the meantime?
Berryman B-12 chemtool in the arosol can, works like a champ!
Old Oct 24, 2003 | 04:54 AM
SMOKNZ's Avatar
That is correct. I know the flat surfaces I can stone, but it's the irregular surfaces i need to get.
Bill
Old Oct 24, 2003 | 07:30 AM
94_Z28_guy's Avatar
WD-40 and rag, fine steel wool, or scotch bright pad. Steel wool leaves small filings behind so I wouldn't recommend it.
I used wd40 and scotch bright, worked pretty well, no scratching.
karpetcm
Aug 14, 2015 03:02 PM
Aug 5, 2015 08:35 AM
4586
Jul 31, 2015 06:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Jul 17, 2015 02:47 PM
