What r some causes 4 my 94 camaro z28 to back fire?
Old Apr 11, 2009 | 02:58 PM
arlahin's Avatar
MY 94 camaro z28 is back firing. Could the ignition coil b makin my car back firing?
Old Apr 11, 2009 | 03:23 PM
94 Assault z28's Avatar
do you mean miss fire? and where do you hear it up at the engine or at the exhaust?
Old Apr 11, 2009 | 03:55 PM
As noted.... clarify. Is it popping in the exhaust? Is it popping back into the intake manifold? Under what conditions does it backfire.... what RPM, what engine load?
Has your engine been modified in any way?
Old Apr 12, 2009 | 12:40 AM
arlahin's Avatar
My engine is basically stock the popping is comin from tha exhaust. HELP ME
Old Apr 12, 2009 | 09:01 AM
If you want HELP you have to provide the requested info. Let's try this again:
Are you running a cat? Has the exhaust been modified in any way?
Misfires in the engine can cause fuel and air to accumulate in the exhaust and ignite ("pop"). This can be even worse if you have cross-firing between the wires. If that's the case, you need to find out why its misfiring. Could be plugs, wires, IC Module, coil, Opti, injectors, sticking valves, etc.
Knowing WHEN it pops may help us figure out what is causing it. Youo can't just jump to the conclusion that its the coil.
Have you scanned it for codes?
Old Apr 13, 2009 | 08:18 AM
THE_RUCKUS's Avatar
I removed my cat.. now when engine winds down I get popping. I am going to have a tune done on my pcm and hope that resolves the issue... if not, I'll put the cat back on.
Old Apr 13, 2009 | 09:51 AM
ulakovic22's Avatar
Popping in the exhaust on decel is fairly common and doesn't necessarily indicate a problem. How long has it done it? Ever since you removed the cat? How long ago did you remove the cat?
Old Apr 14, 2009 | 07:14 AM
THE_RUCKUS's Avatar
yep, it pops on the way down after revving. it's because i removed the cat or at least added to the underlying issue of the car running very rich.
that's why I'm hoping the madz28 tune will lean it out a bit.. i heard that these cars respond very well to a leaner mix.
Old Apr 15, 2009 | 05:41 PM
stopthatman's Avatar
the only time mine ever popped on decel was when i had a hose leak and coolant was dripping on the opti
Old Apr 16, 2009 | 01:39 AM
Bad LT1's Avatar
i have stock manifolds and no cat, and a cutout! and everytime i decel my car backfires.... but thats normal to me i dont see a problem
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
Mad_Ice
Jul 29, 2002 09:44 PM
Jake77444
Jul 21, 2002 05:37 PM
2000silverz28
Jul 20, 2002 06:14 AM
