What r some causes 4 my 94 camaro z28 to back fire?
As noted.... clarify. Is it popping in the exhaust? Is it popping back into the intake manifold? Under what conditions does it backfire.... what RPM, what engine load?
Has your engine been modified in any way?
If you want HELP you have to provide the requested info. Let's try this again:
Are you running a cat? Has the exhaust been modified in any way?
Misfires in the engine can cause fuel and air to accumulate in the exhaust and ignite ("pop"). This can be even worse if you have cross-firing between the wires. If that's the case, you need to find out why its misfiring. Could be plugs, wires, IC Module, coil, Opti, injectors, sticking valves, etc.
Knowing WHEN it pops may help us figure out what is causing it. Youo can't just jump to the conclusion that its the coil.
Have you scanned it for codes?
yep, it pops on the way down after revving. it's because i removed the cat or at least added to the underlying issue of the car running very rich.
that's why I'm hoping the madz28 tune will lean it out a bit.. i heard that these cars respond very well to a leaner mix.
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
