what psi for ET streets
Old Sep 19, 2004 | 11:38 AM
97Z-M6's Avatar
i bough ta set of et street 26 10.5 16. but im wondering what yall are running in as far as air pressure. i figured somwhere between 24 and 18. but what has worked for yall.
oh and does anyone have a 9" they would like to donate to a
caritable cause.
Old Sep 19, 2004 | 11:45 AM
RamAir95TA's Avatar
Re: what psi for ET streets
You might want to try the Drag Race forum, but I'll help you out anyway.
ET streets like a lower pressure. 18-24psi is better suited for a drag radial, not a drag tire.
I found I hooked best with pressure at 14psi.
Keep in mind, chances are you're going to break something with ET streets, especially if you're an M6 and you launch hard.
Old Sep 19, 2004 | 08:13 PM
97Z-M6's Avatar
if i heat them up good would they stick a 3000rpm dump.
they are 26 20.5 16 would it hold
if it blows the rear up ill by a 9"
Old Sep 19, 2004 | 09:08 PM
QCKZ28's Avatar
13psi worked well for my car
Old Sep 19, 2004 | 10:22 PM
94 CAMRO Z28's Avatar
What you want to do is run the highest air pressure that you can with still being able to hook. Obviously this all depends on your car setup. I started at 15psi and worked up to about 17psi being best. Just a small burnout was all I needed and even then, when I dumped the clutch at 4000rpm the car bogged down.
Aaron
Old Sep 19, 2004 | 11:00 PM
camz383's Avatar
12 psi is what i hook best at..
Old Sep 19, 2004 | 11:31 PM
Z-RATED94's Avatar
What 94 CAMRO Z28 said, the highest pressure possible and still be able to hook. It will help your ET and be a little more stable when you let off the gas.
KYWes
Jun 14, 2022 06:52 AM
bunker
Aug 21, 2015 10:21 AM
canuck94z28
Aug 19, 2015 05:50 PM
Louey
Pacific
Aug 7, 2015 01:47 AM
