What a POS!!!!
Old Dec 11, 2003 | 02:53 AM
Heatmaker's Avatar
Advanced Member
What a POS!!!!
Finally got the pump on what a Pita this was...after half way through the grinding the Dremel dies...finished it off with a Drill using the grinding stone. Needless to say the final product ended up looking like that Corky had done it. The pump just wouldn't fit...turned out had to grind away some of the Pump housing it's self....another PITA....who designed this thing?
Pump
Pump2
Old Dec 11, 2003 | 03:36 AM
97WS6SCharged's Avatar
Dude, everyone told you that you would have to grind on the pump housing to make the CSI fit. What are you bitching about?
For the record, CSI is not a POS. Unless the wire breaks.
Old Dec 11, 2003 | 03:37 AM
QCKZ28's Avatar
which one did you get?
i got the CSI, i used the dremel for about 5 mintues on the housing. didnt have any trouble. i used the cutting wheels to notch it out.
jesse
Old Dec 11, 2003 | 04:26 AM
Heatmaker's Avatar
Advanced Member
The grinding I knew about...wasn't aware you had to trim the entire housing though. Just thought it was the 4 little ears...but if you had to grind with a crappy slow poke drill you'd see what the frustrations about...o-well it was worth it.
The grinding stone was kicking ***! Didn't even wear out hardly...the drill dremel wore out first...
CSI....how hard is it to relocate the screws? and include a wiring diagram?
Found an awsome diagram and install guide here...For anyone planning to do this job.
WAter Pump Install
They have a diagram for utilizing a switch or activation light too.
mr28
Apr 20, 2016 05:44 PM
mr28
Nov 23, 2014 11:11 AM
muckz
43
Apr 29, 2003 02:23 PM
fireturd
Middle Atlantic
12
Apr 15, 2003 09:17 PM
grendal
Mar 27, 2003 03:17 AM
