What plugs to run?
Old Apr 11, 2004 | 12:31 PM
TigerWoodsJr's Avatar
What plugs to run?
Ok, my friend has a hesitation we are trying to fix. I think he needs to change his plugs over already. Over the winter he ported and polished the heads and added a fairly aggressive lunati cam. He has new wires that aren't arching and an accell 300+ ignition. What would be the best plugs to run in this situation? Should that be gapped to .050 or less? Thanks.
Old Apr 11, 2004 | 12:35 PM
95 LT1
Old Apr 11, 2004 | 12:38 PM
joeSS97's Avatar
Delco Rapidfires 5
Old Apr 11, 2004 | 01:12 PM
Hyperspeed97z28's Avatar
NGK tr-55
Old Apr 11, 2004 | 01:16 PM
Kevin_97's Avatar
Originally posted by Hyperspeed97z28
NGK tr-55
Old Apr 11, 2004 | 01:17 PM
stock gap at .050 right?
Old Apr 11, 2004 | 01:25 PM
stock gap is correct
Old Apr 11, 2004 | 02:33 PM
CamaroBoy96Z28's Avatar
NGK tr-55
Old Apr 16, 2004 | 01:43 PM
LT1Squirrel's Avatar
theres 2 version of the TR55....which should we use, the TR55GP or the regular TR55?
Old Apr 16, 2004 | 01:57 PM
PatriotTA's Avatar
regular TR55, I think the GPs are platinums. Its up to you if you want to spend the extra $$$ on platinum plugs, I just run the regular TR55s.
Old Apr 16, 2004 | 03:42 PM
Originally posted by joeSS97
Delco Rapidfires 5
I use Rapidfire 3's.
Old Apr 16, 2004 | 04:42 PM
Tim240z's Avatar
Is ANYONE using Champion?
Old Apr 16, 2004 | 04:58 PM
sc93's Avatar
I've always used Bosch single platinums with no problems
(unless you're spraying!)
Old Apr 16, 2004 | 06:42 PM
Mindgame's Avatar
Thumbs up
I run champion coppers in everything I own.
-Mindgame
Old Apr 16, 2004 | 09:37 PM
12SCNDZ's Avatar
Splitfire SF10D's
Frank
