What plugs do you run?
Old Mar 6, 2004 | 08:14 PM
slider's Avatar
I currently run ac delco platinum plugs and have had no complaints, but in an effort to find my not starting in wet weather problem I am gonna change plugs and wires. I'm going with MSD wires. I was thinking just go with NGK TR55 plugs, but not sure yet. I plan on throwing a 75 shot at it shortly. What plugs should I run for that? Can I run plugs made for nitrous applications without any problems before I spray the car?
Old Mar 6, 2004 | 08:18 PM
Hawk's Avatar
I am using NGK tr6 plugs. Use the 2 heat range colder plugs for nitrous, it will run fine NA. Thats what I am using.
Brian
Old Mar 6, 2004 | 08:27 PM
RedHottG2's Avatar
I always used NGK TR-55's
Old Mar 6, 2004 | 09:49 PM
12SCNDZ's Avatar
Splitfire SF10D's.
Your "no start when wet" problem is probably your coil. My old '95 had the same problem.
Frank
Old Mar 7, 2004 | 10:27 PM
slider's Avatar
How many miles do the TR6s usually last?
Old Mar 7, 2004 | 10:34 PM
jtk's Avatar
jtk
I tend to run champions, no real reason, just the brand I settled on
Old Mar 7, 2004 | 11:04 PM
Daryn95Z's Avatar
TR 55's
Old Mar 8, 2004 | 01:11 PM
slider's Avatar
How many miles do the TR6s and TR55s usually last?
Old Mar 8, 2004 | 01:24 PM
Botch's Avatar
Autolite 104s here, P1sc blown 383 @8psi. Good plugs for cheap.
Old Mar 8, 2004 | 06:41 PM
96LT14u2Nv's Avatar
NGK TR55's
no complaints here
switched to them from the delco plats and couldnt be happier
Old Mar 8, 2004 | 07:03 PM
Spinner's Avatar
NGK tr55s
Old Mar 8, 2004 | 07:09 PM
CamaroSS30thAnn's Avatar
buying NGK TR55's here
Old Mar 8, 2004 | 07:27 PM
iiiezekieliii's Avatar
are the ngk's better than the delco platinum plugs on a mostly stock car? The ngk's last for 15k miles correct?
Old Mar 8, 2004 | 07:34 PM
Kevin_97's Avatar
Originally posted by 96LT14u2Nv
NGK TR55's
no complaints here
Same here.
Old Mar 8, 2004 | 09:39 PM
Derrick Redd's Avatar
I'm running Autolite 103's. Ran my best NA and nitrous times with them.
