What is this plug?
Old Jan 18, 2006 | 03:41 PM
69z-28's Avatar
What is this plug?
right on my SMOG pump there is what looks like a connection for a plug to go into but nothing is connected and then there is a line with a plug that looks like it will fit right in, however i think the line has a cap on it similar to the caps that come on skip shift eliminators that you put on the trans. very strang and idk what it is. heres pictures, one of the plug on the Smog pump and one of the wire with the capped plug.
Old Jan 18, 2006 | 11:39 PM
Re: What is this plug?
Looks like it might be the air bleed solenoid for the AIR pump.
See the top right of this...
Old Jan 19, 2006 | 07:26 AM
69z-28's Avatar
hmmm. idk. ill check it out more. it seems like it has a cap on the plug tho. ill determine if thats it for sure.
Old Jan 19, 2006 | 07:38 AM
69z-28's Avatar
ok, you were right thats what it goes to, however the cap DOES have a plug like i thought, i pulled it out a little more and took a picture of the plug and the cap. is this supposed to be plugged in, or not? its weird that theres a cap on it...
Old Jan 19, 2006 | 09:43 PM
69z-28's Avatar
any help? my cars acting up right now and i want to get it running right before i dump more money into it for mods. i doubt this is having any effect on the car but id like to know if anyone has an idea about this?
Old Jan 19, 2006 | 09:57 PM
96ZCamaro's Avatar
Hmm....Doesn't that kinda look like the plug that goes into the winder washer fluid container? Might be mistaken but I'm not for sure.
Old Jan 20, 2006 | 05:07 PM
Jeff H's Avatar
I have the same wire plugged off on my 96 SS. My car doesn't have that bleed valve though and I think that's what it's supposed to connect to. I think there was some recall for that and maybe mine was removed under the recall. I don't think that will cause any problems or the SES light. It just bleeds off any potential exhaust that might get past the AIR check valve. Did you test your AIR check valves to make sure they aren't leaking. They are notorious for going bad. Pull the rubber hose off and try blowing through and sucking back through(not while it's running or hot). You should only be able to get air through it 1 way. If air goes both ways the valve is bad. I just replaced both valves on my SS when I did the headers.
Old Jan 20, 2006 | 11:21 PM
69z-28's Avatar
yea its not throwing a code for AIR, its all getting deleted when the long tubes go in anyways, i need to get this EVAP problem fixed first.
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
