what is this? (pic)
Old Jul 30, 2003 | 11:16 PM
OffspringZ28's Avatar
what is this? (pic)
http://csce.uark.edu/~jgbertr/rb/map.jpg
the hose that says "PRC TBU" that is connected to the TB. Mine is cracked and has no vacuum im sure. what is it?
Old Jul 30, 2003 | 11:19 PM
QCKZ28's Avatar
part of your PCV system, it comes from the passenger side valve cover and goes into your TB.
Old Jul 30, 2003 | 11:20 PM
am i in trouble? the TB connection is out in the open
Old Jul 30, 2003 | 11:21 PM
Zack's Avatar
Thumbs up
crankcase ventiltion hose
Old Jul 30, 2003 | 11:24 PM
QCKZ28's Avatar
thanks for the technical term, i just knew what it was for.
i have mine removed. i put a breather element into the pass valve cover. and plugged the TB with a vaccum cap??dont know the correct word, it just stops air from getting into your TB.
YES you need to get it fixed or do what i did, it is like having a huge vaccuum leak!
Old Jul 30, 2003 | 11:28 PM
predator's Avatar
what that does is allow clean metered air to enter the crankcase to equalize the pressure that the pcvvalve sucks out. which allows for better ring sealing also because negative pressure in the c.c will be more suseptable to letting compresssion escape around the rings
Old Jul 30, 2003 | 11:30 PM
You don't want to leave that pipe exposed. Just get a new hose. P/n 10128365.
Old Jul 30, 2003 | 11:49 PM
could this cause a nasty stumble down low? i hope this fixes it......
Old Jul 31, 2003 | 12:07 AM
QCKZ28's Avatar
yep thats what happens when you have unmetered air in your motor
Old Jul 31, 2003 | 08:36 AM
It actually is more of a vent and at most times air travels from the TB to the valve cover. In some circumstances air does travel the other way, but it is not a vacuum line in the traditional sense. So it might not be the cause of your stumble. Easy to just plug it off to test, though.
Henson071
Dec 30, 2015 09:55 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
meissen
Aug 11, 2015 06:05 AM
cjamen
Jul 27, 2015 12:48 PM
cmsmith
Jul 10, 2015 07:19 PM
