What other valvetrain upgrades needed with cc503 cam swap
Old Apr 10, 2007 | 11:26 AM
  #151
BradcTA's Avatar
I guess they're just loud. I got them at zero lash and did 1/4 turn. I hope that's right. My idle varies form 600-700. You can see the seperation of the puffs of exhaust at idle so I guess it's "loping" but you can't hear it. Maybe TDs will fix that.
Old Apr 10, 2007 | 12:01 PM
  #152
crazydavez28's Avatar
i used to set mine to 1/3 turn but they always seemed loose so i tried 1/2 turn with same results. i guess next time i'll go with 1/4 since more preload didn't make them any quieter.
i have the cc305 and my car idles at 1000 it has a subtle loping sound and when putting around in 1st gear at under 1500 you can really feel the lope
Old Apr 10, 2007 | 12:11 PM
  #153
BradcTA's Avatar
Well, I don't know what's wrong with mine. Maybe it's runing too lean?? You can barely smell it running even right after startup. Before it just about choked you. Would running too lean cause a much smoother idle?
Old Apr 10, 2007 | 01:21 PM
  #154
2000GTP's Avatar
You may not be getting alot of lope just because the grind of cam you have.
Old Apr 10, 2007 | 01:23 PM
  #155
Z95m6's Avatar
You got a very small cam, I wouldn't expect it to lope much.
Old Apr 10, 2007 | 01:32 PM
  #156
BradcTA's Avatar
I guess the XFI280 wouldn't have been too big after all?
I thought with the lift numbers on the XFI268 it would be right about on par with the CCXE503.
Old Apr 10, 2007 | 01:33 PM
  #157
Z95m6's Avatar
Lift does not make lope.
Old Apr 10, 2007 | 01:42 PM
  #158
BradcTA's Avatar
Well that sucks. After all these hours at the computer and calls to CC and it seems I still made the wrong cam choice. My stock cam loped better @ 700rpm than this one does. Tommorow when I get it running again it better be really really fast or I'm gonna be pissed. Just FMI, to change the cam out again I'd have to pull the intake and all that off again wouldn't I?
Should it have been the 503 or the XFi 280 I wonder??
Old Apr 10, 2007 | 02:06 PM
  #159
buzz12586's Avatar
Find out what kind of power it makes first. Would you rather have a cam that lopes and makes less power????
Old Apr 10, 2007 | 02:17 PM
  #160
BradcTA's Avatar
I'd give up 5-10 hp for a mean lope, yes.
Old Apr 10, 2007 | 02:25 PM
  #161
buzz12586's Avatar
Then pull a spark plug wire, ricer.
Old Apr 10, 2007 | 02:34 PM
  #162
BradcTA's Avatar
Ouch...
Old Apr 10, 2007 | 05:15 PM
  #163
Z95m6's Avatar
You'll have to redo everything. The only thing you won't have to do is swap the valvesprings. The smaller cam will probably make more usable power than the 280 but will have less lope. Sounds like the 224/230 was what you should have gone with if you wanted lope.
Old Apr 10, 2007 | 05:31 PM
  #164
BradcTA's Avatar
OK. I just drove it around for a couple minutes. At idle and reving it up it does great, but I'd swear it's not any faster than before, it may be slower! Those rockers are REALLY LOUD too, you can stand at the back of the car and hear them. It's not missing but It feels like the power is going in and out especially above 3K-5K RPMs. Could the rockers possibily being out of adjustment be an issue.
Old Apr 10, 2007 | 05:36 PM
  #165
2000GTP's Avatar
Yes, poorly adjusted rockers can definitely lead to power loss or worse. Have you had the PCM tuned as well?
