what oil should i use
Old Apr 24, 2003 | 05:54 PM
oaklandz28's Avatar
i got a 94 z28 with 90000 miles and i want to know what kind of oil to use for engine, tranny and everything else that requires fluid or oil that i cant think of.
Old Apr 24, 2003 | 06:18 PM
chasmanz28's Avatar
Re: what oil should i use
most people like mobli 1 syn, i would use 10w30 because of the mileage on yr car, you can use mobil 1 products for all yr car needs, ive used mobli 1 syn and never had a problem
Old Apr 24, 2003 | 06:32 PM
LimitedEd1LE's Avatar
If the car hasn't been run on synthetic oil, then don't change to synthetic. All you will do is cause an oil leak.
Old Apr 24, 2003 | 06:51 PM
chasmanz28's Avatar
now why would changing to syn cause a leak?
Old Apr 24, 2003 | 07:08 PM
Mindgame's Avatar
Why?
Because synths have rather powerful detergents in them. Any deposits that are helping the gaskets seal may no longer once synth is used.
If you don't have a leak, then you may not have one using synth. One thing is for sure though.... if you already have a small leak, it's only going to be worse.
Might want to change to a synthetic blend... see if any leaks pop up, if not... then change to synth next oil change.
-Mindgame
Old Apr 24, 2003 | 07:13 PM
chasmanz28's Avatar
Originally posted by Mindgame
Why?
-Mindgame
good answer
Old Apr 24, 2003 | 07:22 PM
Jcb890's Avatar
hey, i run 5W 30, if i switch to 10W 30 will i notice ne difference and should i do this change? i have a 95 a4 w/ 122,xxx on it.
thanx,
jake
Old Apr 24, 2003 | 07:24 PM
chasmanz28's Avatar
thanx,
jake
yeah i would with that amount of mileage, maybe even 10w40, give ya a little more oil pressure to
Old Apr 24, 2003 | 08:01 PM
BOWTYDE's Avatar
I use Castral Synth Blend 5w30.
Old Apr 24, 2003 | 08:02 PM
BOWTYDE's Avatar
Why?
-Mindgame
Should I worry about that with Tranny fluild aswell?????
Old Apr 24, 2003 | 08:05 PM
chasmanz28's Avatar
i would think the same thing applies, if you have no leaks or tranny problems i would
Old Apr 24, 2003 | 08:33 PM
stik6shift98's Avatar
defintly run fully synthetic
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
