what is the oil pressure for a 93 lt1
Old Aug 3, 2010 | 01:49 PM
camaro9778789's Avatar
i was wondering if anyone knows the normal oil pressure for a stock 93 lt1???
Old Aug 3, 2010 | 01:53 PM
mine is running just below 80 dose anyone know if this is a bad thing or what i need to do to fix this problem?
crash4cyl's Avatar
you should have at least 20 psi at idle....at least that's what my 93 runs....if it's really cold it'll hit 80 at idle, but that's really really cold out...
Old Aug 3, 2010 | 02:01 PM
brucer's Avatar
you should be around 20-30psi at idle.. about 40-50psi at at about 2000rpm
your old post on the subject... explains why your gauge is pegged
https://www.camaroz28.com/forums/sho...d.php?t=766096
Old Aug 3, 2010 | 03:14 PM
RamAir95TA's Avatar
LT1/SBCs can survive on surprisingly little oil pressure. GM spec is 6psi at idle and 10psi for every 1,000 RPMs.
Old Aug 3, 2010 | 08:08 PM
so you dont think my car running at around 80psi when im driving will hurt anything in my engine?
Old Aug 3, 2010 | 08:28 PM
rclearyiii's Avatar
If that is an accurate reading..just make sure you use a quality oil filter that can hold up under pressure.
Old Aug 3, 2010 | 08:54 PM
brucer's Avatar
if you go read shoebox post in your other thread you started on the same topic.. you will read that your sensor is grounded out, causing your gauge to peg... that means the sensor is bad or the wiring is faulted..
with the picture you gave in your other post, the oil leaking from the end of your sensor should tell you it needs replacing.
Old Aug 3, 2010 | 08:59 PM
RamAir95TA's Avatar
Did you read your other post? It is highly unlikely that your actual oil pressure is 80+. Like mentioned, continuity is likely lost and the gauge is pegged.
lt1-xjs's Avatar
I just read somewhere that a bad sending unit will peg the gauge with a false reading on the f-body.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Z28countrymama
Jan 22, 2015 02:50 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
